have a question if there is a way of using udim's with VrayProxy?
also, is it possible to control the scale of an object imported from OBJ by using "Convert and load non-vrmesh geometry" option? When I import the model from zBrush in a normal way, it has the same size like before exported to zB, while I import it as a proxy the scale is multiplied by x10. To avoid it I use 3D Print Export plugin in zBrush where I can put size of the object in millimeters to make sure it will match what I have in MODO in this case. Was wonder if there is a shorter way of doing it?
thanks,
P.
thanks,
P.
