Does vray have this to speed up rerenders, I cannot find it in the interface.
store Irradiance map
You can choose to auto-save the irradiance map after rendering or manually save it using the Save button.
Use the mode option to switch between generating a new irradiance map or loading an existing one from disk.
Note that the Auto save and Load file path channels are different.
Greetings,
Vladimir NedevVantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
Oh, you originally meant the Store with Irradiance Map option for the lights ?
You should generally avoid this as it leads to lower quality soft shadows.
But, yes, that's where you enable it, from the V-Ray Light tab.
I take it that one uses modo's save/load function
Greetings,
