store Irradiance map
  • store Irradiance map
    Does vray have this to speed up rerenders, I cannot find it in the interface.
    Yes, in the V-Ray GI tab in the Render settings.
    Greetings,
    Vladimir Nedev
      You can choose to auto-save the irradiance map after rendering or manually save it using the Save button.
      Use the mode option to switch between generating a new irradiance map or loading an existing one from disk.
      Note that the Auto save and Load file path channels are different.
      Greetings,
      Vladimir Nedev
        thanks, I take it that one uses modo's save/load function and its not somewhere in the Vray interface other than enabling it in Vray lights
          Oh, you originally meant the Store with Irradiance Map option for the lights ?
          You should generally avoid this as it leads to lower quality soft shadows.
          But, yes, that's where you enable it, from the V-Ray Light tab.
          I am not sure which save/load function you are talking about.
          Greetings,
          Vladimir Nedev
            thanks, Vladimir
