Surface ID strange rendering
  • Surface ID strange rendering
    Hello, why am i seeing wooden texture in Surface ID render element? I thought it is always flat colour areas.
    Hey, dmiko,
    Thank you for the feedback, Yes, it is. The Surface ID used flat color, but you have had overlapping geometry. Clean your mesh and render it once. Btw, you can use and V-Ray render outputs such as Render ID || Material ID || Object ID, the last two I strongly recommend you.
    Cheers,
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      That's really strange, I will need a scene to look at.
      I am not sure overlapping geometry can cause this.
      Greetings,
      Vladimir Nedev
        Hello,
        I cleaned the geometry, there is no overlapping. I rendered Object ID Material ID and render ID, the wooden fassade is still messy, other materials render fine.
        I will send you guys the scene.
        Daniel
          Howdy, dmiko,
          Can you check the result for Surface ID with Modo default render?
          I can reproduce only when into the scene I had overlapping geometry: https://drive.google.com/open?id=1cL...MfblcVJTUZFB2x but this is not an issue with V-Ray at all.
          Cheers,
            Modo native surface ID works fine
              I have now rebuild the wood materials from scratch and it renders the mask correctly now, must be some weird glitch
