BAKING in MODO
  • BAKING in MODO
    Is it possible to use the "Bake to Texture" command in the shader tree with a VRay Blend material. All I'm getting is a solid black result : (
    Any advice would be appreciated. THANKS! : ))
    No, that won't work. The V-Ray textures/materials do not work with the Modo renderer.
    Greetings,
    Vladimir Nedev
      Hi Vlad, is there a baking function in Vray for Modo renderer? Or some other work around??
      Thanks so much : )
      F
        No, unfortunately, baking is not available in V-Ray for Modo. Sorry about that.
        Greetings,
        Vladimir Nedev
          OK. So the only way around this would be to create all the materials that require baking as Modo materials, bake them and re. import the images to use for the V-ray materials?
          I am trying to optimize a scene for rendering and the diffuse attribute is a blended material that has several AO processing layers too...
          Thanks again : )
