Vray 3.6 Not Installing For Modo 14.0
  • Vray 3.6 Not Installing For Modo 14.0
    Hi
    I've just downloaded Modo 14 and also the Vray installers from Downloads section in the Chaos site. After installation, VRay does not show up at all in the Modo 14 menus.
    Please could you advise?
    Many thanks
    Originally posted by peepo View Post
    Hi
    Many thanks
    Hey Peepo
    I downloaded and installed the last Nightlies build before installation of modo 14.
    Here it works with modo 14.
    Regards
    Phil
    Main computer : Threadripper 2990WX - 2 x GForce 1080 8Go - 1 GTX 1070 8Go - 64 Go
    Softimage 2015 x64 | Lightwave 2020 | modo v14
      Thank for the quick reply Phil - Im using Vray 3.7 and just tried this from the nightlies:
      vray_adv_37001_modo_mavericks_x64.dmg
      and from the downloads section:
      cgls_mac_5.4.0.bin.dmg
      Just ran the installer but still no VRay menu shows up int Modo 14.
      Any other ideas please?
        I've just upgraded to VRay Next v4.1 but this does not work with Modo 14 either. There are no nightlies for VRay Next for Modo that I could find - only VRay 3.6.
        Any help from Chaos group would be greatly appreciated!
          The V-Ray next nightly builds have an updated kit config so they load into 14. You need to email supportATchaosgroupDOTcom and ask for access to the modo "next" nightlies (even if you already have access to 3.x)
          NOTE: The following instructions use Windows paths. I'm not a Mac user so you'll have to find where these are.
          For 3.7 (nightly) users, you can edit the kit yourself:
          1) Open this file in a text editor:
          "C:\Program Files\Chaos Group\V-Ray\MODO x64\vray4modo\1101\index.cfg"
          2) Change the first line to:
          Code:
          <configuration kit="vray" version="3.70.01" and="app64" and="rel]1099" and="rel[1500">
          For V-Ray Next (If you don't want to use the V-Ray nightlies for some reason):
          "C:\Program Files\Chaos Group\V-Ray\MODO x64\vray4modo\plugins\1101\index.cfg"
          Code:
          <configuration kit="vray" version="4.12.01" and="app64" and="rel]1099" and="rel[1500">
          Win10 Pro 64 / AMD Ryzen 9 5950X / 128GB / RTX 3090 + 1080 Ti / MODO
          I am the resurrection, and the life: he that believeth in me, though he were dead, yet shall he live - Jesus Christ
            Hey,
            Thank you for the post.
            // For the V-Ray 3.X. users: for now the most simple method is to update the configuration as funk described yet.
            WINDOWS USERS ONLY:
            1) Open that file in a text editor:
            Code:
            FOR MAC OS USERS
            1) The same drag and drop in Terminal
            Copy//Paste
            sudo nano /Applications/ChaosGroup/V-Ray/Modo_x64/vray4modo/pluggins/1101/index.cfg
            Code:
            // For the V-Ray Next users, The support for Modo 14.01 was added to nightly builds so you can download it and working without limitation if you don't have access please ask support for permission.
            // For the V-Ray Next users: with trials working with an official build only: The best to handle this issue, is to complete the funk steps.
            WINDOWS USERS ONLY:
            Code:
            Cheers and good health
            Boyan Nalchadjiiski | QA Engineer @ Chaos |
            E-mail: boyan.nalchadjiiski@chaos.com
              Thanks very much guys!!
              Does anyone know where the file on MacOS is please?
              Wishing you all good health too!
                Hi, I have a similar problem.
                Modo 14 and V-Ray 3.6 on Mac OS Catalina.
                Went to the index.cfg file, screengrab attached.
                File is locked and can only edit by making a copy.
                Is it ok to make the copy then edit, then delete origonal and rename the copy? Click image for larger version
Name:	Screenshot 2020-03-20 at 14.26.29.png
ID:	1064825Click image for larger version
                  Found it - Slarty - you could use a terminal window and go the directory where index.cfg is and type:
                  sudo vi index.cfg
                  and make the change that way?
                  All works in Modo 14 now!
                    Yes, to change this file you should have the privilege or use sudo for this as well
                      Thanks Guys,
                      All working now.
                        Correct Mac path for terminal is: sudo nano /Applications/ChaosGroup/V-Ray/Modo_x64/vray4modo/1101/index.cfg
                          // Yes, if you're using V-Ray 3x for Mac.
