VRay Next for Modo Not Rendering Spec Map
  • VRay Next for Modo Not Rendering Spec Map
    Hi
    I though this was just a VRay Cloud issue (have posted on cloud forum and logged with support), but have just done a local render using VRay Next on my machine and spec map is pure black, even though on a preview render, it shows up correctly.
    Is this bug fixed on the nightlies?
    Many thanks!
    Hey, Pali,
    Thx for the information, could please change the GI settings secondary LC to BF, and if you provide me with the scene file I can be more specific. You can put a cube or sphere with the texture and material setup, I don't need the full scene for now.
    Cheers,
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      You are talking about the specular render element, right ?
      In V-Ray Next, there are some changes to how we split a light's reflection between the reflection and specular elements, but my memory is a bit fuzzy on the details.
      Can you try the "reflection" render element, and see if the missing information is there ?
      Greetings,
      Vladimir Nedev
        Hi Vladimir - thanks - yes, the reflection pass is ok. Should i just disregard the spec pass now?
          No, I think it still has information in other cases.
          Greetings,
          Vladimir Nedev
            Would be great to have the spec map somewhere like it used to be....
              Hey, Pali,
              thank you for the feedback I'm looking at it, I will answer today. As far as I can see, in your scene file, you've been disabled specular option in your V-Ray Light settings.
              Cheers,
                Hi Boyan
                Thanks buddy! I was trying to follow Vladimir's example scene for caustics (which worked really well), so only one of the lights should have effect spec turned off, which was the one generated the caustics.
                Im pretty sure that it's not just on this scene, as I've had exactly the same in another totally unrelated project, without caustics, where the spec map was totally black. I've just added the spec map from the RE windows like I always do.
                If you need any more info, please just let me know.
                  Hey, Pali,
                  Thx for the feedback, well I think if this option is disabled, the only GI (Env.Dome) can create the specular output, otherwise, render will be black because there is no a source of rays for specular output.
                  Cheers,
