A replicator that uses another replicator as the Prototype will not render in V-ray.
Nested Replicators do not render
Yes, this doesn't work currently. We have code in the V-Ray core that does this ( I think it was used for the our Softimage ICE implementation).
I need to check if it will be possible to use it in V-Ray for MODO.
Greetings,
Vladimir NedevVantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
There is another problem with replicators. If you drag a replicator to the schematic and connect multiple prototypes, vray only renders 1 of the prototypes.Win10 Pro 64 / AMD Ryzen 9 5950X / 128GB / RTX 3090 + 1080 Ti / MODO
I am the resurrection, and the life: he that believeth in me, though he were dead, yet shall he live - Jesus Christ
Originally posted by nickrart View PostA replicator that uses another replicator as the Prototype will not render in V-ray.
The first problem is that V-Ray will not use a shader tree group mask when it is set to a Replicator item. The mask will be ignored.
The second problem is that if you are using a Variation texture for a Replicator that uses another Replicator as prototype, the variation will
be based on the particles IDs of the nested Replicator only. Basically each copy of the nested Replicator will have the same colors applied.
Let me know if you need these features for achieving a certain effect, and I will see what I can do. They will be harder to fix as internally
V-Ray doesn't have a "shader tree" concept.
Greetings,
Vladimir NedevLast edited by vladimir.nedev; 30-10-2014, 01:13 PM.Vantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
Originally posted by 1funk View PostThere is another problem with replicators. If you drag a replicator to the schematic and connect multiple prototypes, vray only renders 1 of the prototypes.
Thank you for pointing it out. It was a very easy fix, but I had no idea that you can connect the prototypes in the Schematic and that you can have more than one connected.
Greetings,
