Crash using shader Opacity with RT active
  • Crash using shader Opacity with RT active
    Modo crashes when using the opacity spinner for a shader object. Like this:
    http://screencast.com/t/HyB6YSeQ
    Apologies the screen capture is so fast - if it's not clear, the crash occurs when I try to drag the opacity control, below.
    Cheers - Chris
    I can reproduce this. Thank you for finding it.
    It seems to actually happen on all shader tree changes that cause V-Ray for MODO to re-export the material
    (as opposed to re-exporting only the value of a channel to a V-Ray parameter). This includes a lot of MODO's
    advanced material channels (reflection/specular amount, transparency amount, etc.). This is because these
    channels affect the internal material network that will be exported (for performance reasons).
    This bug is present on Windows too. But the memory protection on Mac OS X / Linux makes it more apparent.
    I will write back here when I fix it.
    Greetings,
    Vladimir Nedev
      Thanks for the confirmation Vladimir - good hunting!
        The crash is fixed for the next open beta build (3.00.06).
        Greetings,
        Vladimir Nedev
