displacement
  • displacement
    Having 1 item with 2 different materials applied to different polygons will render the same displacement on both if a vray geometry package is applied. Is this the right behavior?
    The problem is not the V-Ray Geometry Properties, it should be the same without them.
    Currently you can't have a different displacement distance in different materials applied on the same mesh. One of the materials will be chosen and its displacement distance used.
    There is actually a TODO in the code to fix this, that I have completely forgotten about. I will see if it's possible to fix it without too much trouble.
    Greetings,
    Vladimir Nedev
      I haven't tested with and without the object package... just thought I will give the info of my current scene
      This is not a deal breaker, thanks Vladimir.
