Hello,
Would it be possible to get a version of the VDenoise plug-in for Nuke 11.3 ? We're actually using Nuke 11.3v1 on Windows. The most recent build in the download package is for Nuke 11.2.
Thanks so much.
- Bill
We actually have it recompiled, we have to update the file in the docs section. In the meantime you can email me to vlado@chaosgroup.com and I'll get it to you.
Since you are asking for the plugin, I assume you are using it. Any comments/suggestions? Is it working well for you?
For me, it works brilliantly. I usually shuffle out all my render elements for more control over each light select element, reflections, refraction's etc. Then I can apply the denoise node before bringing them back together. I have greater control then to apply variable strength denoiser to each element. For example reflections may have more cleanup than the others. I can get away with rendering with a noise threshold of somewhere between 0.02 and 0.05 in vray, depending on the scene, which is an incredible reduction in render times, especially on a GPU setup.
This plugin is key to my final stage of working. Thank you for this!!
We have been using VDenoise since October and it not only provides very good quality results, it also reduces our render times substantially. I sent you an email directly requesting a copy of the plug-in.
Thanks. This plug-in is really helping us!
