VDenoise plugin for NUKE
  • VDenoise plugin for NUKE
    Is it possible to update the VDenoise plugin for NUKE to work with Nuke 11.2 (Latest). Thank you kindly.
    It's already updated already; if you go to
    https://docs.chaosgroup.com/display/...epluginforNuke
    and re-download the .zip file, it should contain versions for Nuke 11.2
      Hi Vlado, thank you all working perfectly.
      Regards
        Would it be possible to get a version of the VDenoise plug-in for Nuke 11.3 ? We're actually using Nuke 11.3v1 on Windows. The most recent build in the download package is for Nuke 11.2.
        Thanks so much.
        - Bill
          We actually have it recompiled, we have to update the file in the docs section. In the meantime you can email me to vlado@chaosgroup.com and I'll get it to you.
          Since you are asking for the plugin, I assume you are using it. Any comments/suggestions? Is it working well for you?
            For me, it works brilliantly. I usually shuffle out all my render elements for more control over each light select element, reflections, refraction's etc. Then I can apply the denoise node before bringing them back together. I have greater control then to apply variable strength denoiser to each element. For example reflections may have more cleanup than the others. I can get away with rendering with a noise threshold of somewhere between 0.02 and 0.05 in vray, depending on the scene, which is an incredible reduction in render times, especially on a GPU setup.
            This plugin is key to my final stage of working. Thank you for this!!
              Hi Vlado,
              I couldn't have said it better.
              We have been using VDenoise since October and it not only provides very good quality results, it also reduces our render times substantially. I sent you an email directly requesting a copy of the plug-in.
              Thanks. This plug-in is really helping us!
                Is it possible to update it for NUKE 12v2?
                www.gaell.com
                  If you download the files again, there should be a Nuke 12 version as well.
                  Cheers,
                  Georgi Zhekov
                  Phoenix Product Manager
                  Chaos
                    That's great!! thanks.
                    www.gaell.com
                      could this be complied for nume 12.1? thanks
                        There should already be a 12.1 version uploaded at the same place https://docs.chaosgroup.com/display/...OLS/Misc+Tools
                        Alex Yolov
                        Product Manager
                        V-Ray for Maya, Chaos Player
                        www.chaos.com
