V-Ray Next lens effects plugin for Nuke - where can we access it?
  • #16
    Hello, confirming Lens Effects and VRayDenoiser latest releases for Nuke 14.0 aren't working for 14.1 on Windows (as expected for a point release change). On creation, VRayDenoiser.dll: "The specified procedure could not be found." Is there an estimate when these will be updated again (also for Nuke 15)? Thanks,
    Jens
    • #17
      We'll see to it, although I can't share any ETAs right now.
      How urgent is this for you? We may be able to look into it in January, will this be OK?
      Alex Yolov
      Product Manager
      V-Ray for Maya, Chaos Player
      www.chaos.com
      • #18
        Originally posted by yolov View Post
        We've updated the lens effects and denoiser plugins and they're now compatible with Nuke 14.
        You can download them from the usual place: https://docs.chaos.com/display/VRAY4TOOLS/Misc+Tools
        Hello. Any plans to update it for Nuke 15? I tried install for Nuke 14, but it give an error
        • #19
          Yes, coming soon. We've built them internally for 14.1 and 15 and we're currently running some tests to verify everything is in order.
          Once we've made sure all is good - I'll post an update here.
          Alex Yolov
          Product Manager
          www.chaos.com
          • #20
            Alright, we've uploaded the builds for 14.1 and 15.0 at the usual location. Let us know if all is good, our tests didn't uncover anything our of the ordinary.
            Alex Yolov
            Product Manager
            www.chaos.com
            • #21
              Will these work in Nuke 15.1 ?
              • #22
                There's a chance they don't, since Nuke usually break compatibility with point-releases.
                Feel free to try it out and let us know if it doesn't.
                Alex Yolov
                Product Manager
                www.chaos.com
                • #23
                  I have to preface this with, I have never tried it in any other version of Nuke. But when I try to install VRayLensEffects for Nuke 15.1 I do see the VRay menu, and When I try to add a node I get this:
                  That path is correct, and was set in the environment variable per the README (and yes, it is vray_nuke_lenseffect/ with no "s", even though the readme showed an "s" the actual path did not have one.
                  If I copy the path of the dll I get:
                  "C:\Program Files\Nuke15.1v1\plugins\vray_nuke_lenseffect\VRay LensEffects.dll"
                  Note I tried putting the path in double quotes in the environment variable dialog "C:\Program Files\Nuke15.1v1\plugins\vray_nuke_lenseffect" That did not work at all, it would not even find the vray menu.
                  I tried putting it in quotes and using forward slashes. Still no luck. I tried forward slashes only, no backslashes, no quotes. It finds the menu, but I get the same error as above (but with forwards slashes).
                  It looks like no quotes is correct, but something is not being found (entry point changed perhaps?)
                  Any thoughts?
                  Thanks.
                  • #24
                    Sure would be great to get an updated build of this for 15.1, pretty please. This sort of extra tool is part of what makes the VRay ecosystem so attractive.
                    • #25
                      Hello,
                      Any updates for build for 15.1?
                      • #26
                        We're on it. Sorry for the delay.
                        As soon as we have something ready - I will update the thread.
                        Georgi Zhekov
                        Phoenix Product Manager
                        Chaos
                        • #27
                          Thanks for the update. Looking forward to it.
                          • #28
                            You can now download the 15.1 build from the usual place here - https://docs.chaos.com/display/VRAY4TOOLS/Misc+Tools
                            Georgi Zhekov
                            Chaos
                            • #29
                              Awesome. Thank you!
