using texture without VRayMaterial
  • using texture without VRayMaterial
    out of curiosity: What is Vray doing when a texture is connected directly to the geo as material without the use of a VRayMaterial node?
    In the absence of lights it seems to mimic what Nuke does which is great. But as soon as lights are involved it produces a bright edge where the alpha is not solid.
    I would have assumed that this sort of "lazy" setup would yield the same as a VRayMaterial node with it's diffuse colour connected to an unpremultiplied texture and the opacity to the respective alpha.
    Attached is an example.
    Cheers,
    frank
    Hi Frank,
    Textures plugged directly as material as translated differently than when going through a VRayMtl node or equivalent - in this case they are wrapped within a BRDFDiffuse plugin.
    I looked at the problem you describe and indeed the used plugin calculates something a bit unexpected with a texture with an alpha between 0 and 1.
    Without bothering with details, it's something easily fixable.
    You can even fix it now using a simple post-translate script :
    Code:
    from vray.utils import *
    brdfDiffusePlugins=findByType("BRDFDiffuse")
    for brdfDiffuse in brdfDiffusePlugins:
      brdfDiffuse.set("color",AColor(0,0,0,0))
    Thank you for reporting this.
    Chris
    Christophe COT
    Software Developer - Chaos
    christophe.cot@chaos.com
      Great, thanks for confirming Chris. It's no big deal, just something a little unexpected for compositors.
      Cheers,
      frank
