Grass and Fur Settings not saved
  • Grass and Fur Settings not saved
    I am on V-Ray Revit 2019 version 4.00.05. I will enable fur/grass for my grass material and it will render it fine. I will close out of project and Revit, and then open project and Revit and fur/grass settings are reset. Is there a setting I am missing?
    I can confirm that this is a bug. A temporary workaround until we fix it would be to export the fur settings to an .xml file, so that you can easily import them later on.
    Ana Lyubenova
    Product Manager
    www.chaos.com
      Hi cmathew ,
      This issue is fixed with the new Grass/Fur workflow introduced in Update 1. You can download the update here.
      Best,
      Ana
      Ana Lyubenova
      Product Manager
      www.chaos.com
        Hi Ana Lyubenova This same issue seems to appear in Vray 6 for Revit. Vray forgets the fur setting even without closing the project. In vray 5 this was working fine and now the same project is updated to vray 6 and the fur is not working anymore. I have to apply the fur setting again and again.
          Dear timo_jyrinki​, hello.
          Just tested this with our latest official build - works as expected, no issues.
          Could you please share the following:
          • exact Revit version
          • exact V-Ray version - screenshot from Help > About
          • have you tried it in a blank new project with an object with assigned Fur
          • is it a BIM 360 project or a local one
          • is the Fur in a linked file or not
          Waiting for your answer.
          TS
          Tsvetomira Girginova | chaos.com
          3D Support | contact us
            I created a new project and it seems to be working fine. The old project however loses the fur assignment and I have to reset it again and again. There are no links in this project and it is not a BIM360 project.
            I'm thinking possibly completely resetting all vray data and starting over. Maybe that would help.
Name:	vray version1.jpg
            Revit version:
            24.2.0.63
            20231029_1515(x64)
            2024.2.0​
              Is it correct that even if you fix your Fur assignments and save your Revit project file, the next time you open it, the Fur assignments are lost? Do you observe this behavior with any other type of V-Ray asset assignments?
              Ana Lyubenova
              Product Manager
              www.chaos.com
                Hi, Yes and also it is lost without even closing revit project. Possibly scatter does this too, but haven't done separate tests for it.
                  Hi, I think I located the problem. The fur settings disappear when synchronizing with the central model. It is a workshared model. I was able to replicate the problem with a new blank workshared model too. If the model is not workshared the problem does not occur.
                    Hi, Ana Lyubenova Looks like the problem does not occur when I first save settings and then disable Vray before synchronizing. Without disabling Vray Revit loses the fur settings.
                      Thanks timo_jyrinki,
                      We'll investigate it.
                      Ana Lyubenova
                      Product Manager
                      www.chaos.com
