Error Launching Vray on revit 2020 startup
  • Error Launching Vray on revit 2020 startup
    Since the last update, I can no longer run the VRAY module when starting REVIT.
    Here is the error log
    Click image for larger version  Name:	v ray problem.JPG Views:	0 Size:	49.6 KB ID:	1117026
    Thanks
    Hello Kevin,
    It looks like a .dll file is missing from your V-Ray installation.
    Can you try to uninstall V-Ray manually, then reinstall it.
    If the issue persists, we'll also need to know if you're using any specific Revit addins.
    Best,
    Ana
    Ana Lyubenova
    Product Manager
    www.chaos.com
      hello Anna,
      I verified, the dll is already in the folder of Vray location
      I have already uninstall V-Ray manually, ans reinstall it. the issue still persit.
      The only addin of revit,i have, is PyRevit.
      thanks
        Kevin,
        Can you send us your exact V-Ray for Revit version as well as your exact version of Windows. It would be best if you simply screenshot both "About" windows. In addition, the version of PyRevit too (just in case).
        Best,
        Ana
        Ana Lyubenova
        Product Manager
        www.chaos.com
          Thanks
          Kevin
            Please try the recommendation in this post: https://answers.microsoft.com/en-us/...d-ae0e197782e5
            It looks like the issue may be caused by corrupted system DLL. Please advise if this has solved the problem for you.
            Thanks,
            Tanya Dilkovska-Petrova
            V-Ray for Revit Team Lead
            Team Lead
            V-Ray for Revit
            www.chaosgroup.com
              It works, the problem is solved.
              Thanks a lot !
