help , render error
Hello huynguyen206,
Can you take another screenshot but this time, please, expand the error message?
Simply click on Show details and take a screenshot.
Thank you,
AnaAna Lyubenova
Product Manager
www.chaos.com
Huy,
This issue is related to the Revit.ini file. Here is what you can do:
1. Close Revit.
2. Find the Revit.ini file located here: C:\Users\DELL\AppData\Roaming\Autodesk\Revit\Autod esk Revit 2016
3. Open the Revit.ini file with a text editing program (e.g. you can use Notepad)
4. Find the parameter named IESFileLocation=. You need to type the path to your IES files there.
For example if you use the default location of Revit IES files, it will look like this: IESFileLocation=C:\ProgramData\Autodesk\RVT 2016\IES
5. Save the Revit.ini file. Open Revit and try to render using V-Ray.
It is good to save a backup copy of the Revit.ini file before you start editing it.
Let me know if this helps.
AnaAna Lyubenova
Product Manager
www.chaos.com
