help , render error
  • help , render error
ID:	887233 render error
    Hello huynguyen206,
    Can you take another screenshot but this time, please, expand the error message?
    Simply click on Show details and take a screenshot.
    Thank you,
    Ana
    Ana Lyubenova
    Product Manager
    www.chaos.com
      thank you,
      huy
        Hello Huy,
        Here is what I need you to capture:
        Cheers,
        Ana
        Ana Lyubenova
        Product Manager
        www.chaos.com
          sorry ana
            Huy,
            This issue is related to the Revit.ini file. Here is what you can do:
            1. Close Revit.
            2. Find the Revit.ini file located here: C:\Users\DELL\AppData\Roaming\Autodesk\Revit\Autod esk Revit 2016
            3. Open the Revit.ini file with a text editing program (e.g. you can use Notepad)
            4. Find the parameter named IESFileLocation=. You need to type the path to your IES files there.
            For example if you use the default location of Revit IES files, it will look like this: IESFileLocation=C:\ProgramData\Autodesk\RVT 2016\IES
            5. Save the Revit.ini file. Open Revit and try to render using V-Ray.
            It is good to save a backup copy of the Revit.ini file before you start editing it.
            Let me know if this helps.
            Ana
            Ana Lyubenova
            Product Manager
            www.chaos.com
