Revit Cloud Model Freezes after Sync
  • Revit Cloud Model Freezes after Sync
    I have a team of six working in a revit model. We are using Vray for Revit to render. Revit 2023.0.11.19. Vray 6.10.03.
    Whenever we sync the process completes successfully, but revit then freezes.
    Dear pierre_roberson1​, hello.
    Thank you for contacting us.
    Please take a look at this forum thread and confirm are you experiencing a similar thing.
    In order to be more helpful, please answer the following questions:
    • Is the Central model located at BIM 360 or on a local server?
    • Are all six people working with V-Ray (is V-Ray enabled on these six machines) or not?
    • With how many files (this only or more) are you seeing this behaviour?
    TS
    Tsvetomira Girginova | chaos.com
    3D Support | contact us
      Hello, my problem is similar, though not exactly the same as what's described in the other thread.
      We are able to sync successfully, but after syncing the model freezes.
        Hi again,
        Please answer the additional questions as well + is the freeze visible if V-Ray is disabled during the sync?
          TS
          The model is located on BIM360
          Not everyone using Vray. 3 of 6 are using Vray
          It appears to only occur on one project at this time. We have another project that is in Revit 2022 that works fine so far
          If Vray is disabled (including after it being used) the model syncs fine with no freezing
            @tsvetomira.girginova​ - Hi any thoughts or recommendations?
              Hi, pierre_roberson1​.
              Unfortunately this behaviour has been encountered previously with Revit 2023 and is logged in our system with REVIT-4329 number.
              If we compare the non-problematic file (used with Revit 2022) and this one - is there a difference in complexity?
              Please also confirm that all V-Ray users are using the exact same V-Ray version - very important to ensure fluent working process.
                Hi Pierre,
                In order to assist you, we will need to reproduce the issue in our environment which might take some time.
                One thing that I don't get from the above description is if the freeze occurs to everyone in your group or to a specific user?
                Regards,
                Ana
                Ana Lyubenova
                Product Manager
                www.chaos.com
                  tsvetomira.girginova​, we are all using the same version of Vray.
                  Ana Lyubenova​, the freezing occurs for any user that runs a Vray rendering and then synchronizes.
                    Ana Lyubenova​, I would be happy to add you to our Revit BIM 360 Cloud environment so that you can test it on your end. By the way, I spoke to my team an was informed that the issue is occurring on two projects at this time.​
                      pierre_roberson1, it would be great if you can add us to your BIM 360 environment. We might need 2 spots though - one for either me, or a QA on our end + one for a developer (because they need to identify where the issue occurs in the code).
                      However, we need to start with something simpler -> we'll need both the V-Ray and Revit log files generated after the freeze occurs. So, after the freeze occurs, on the machine it occurs, wait for the freeze to complete and then navigate to:
                      1. For the V-Ray for Revit log file -> C:\Users\<user name>\AppData\Roaming\Chaos Group\V-Ray for Revit 2024\Logs -> we need the most recently generated log file
                      2. For the Revit journal file -> C:\Users\<user name>\AppData\Local\Autodesk\Revit\Autodesk Revit 20**\Journals -> we need the most recently generated journal file
                      One more thing that needs a clarification. Is the rendering actually running during the synchronization?
                      Ana Lyubenova
                      Product Manager
                      www.chaos.com
                        Hi Ana,
                        I am working with Pierre on this project so I will be moving forward with this issue.
                        I have located both the V-Ray and Revit log files, but am having difficulty attaching the .txt files to this post. Also, the freeze happens whenever V-ray is opened, whether the V-Ray frame buffer is open or not.
                        Let me know if need any more information, thank you!
                          Hi Stephanos,
                          You can email those files to me at ana.lyubenova@chaos.com
                          Thank you,
                          Ana
                          Ana Lyubenova
                          Product Manager
                          www.chaos.com
