Hi all! I'm working on a script using Vray Standalone for Revit. I'm rendering multiple adaptations of a vrscene file. I want to import my Vray xml settings file for one specific render so I can enable Z-depth. Is this possible?
The documentation states:
"-configFile="path/to/config/file" – The path and file name to the V-Ray config file, which contains paths to the V-Ray plugins. Note that additional paths for V-Ray plugins can also be specified with the VRAY_PLUGINS_x86 and VRAY_PLUGINS_x64 environment variables. The default is vrayconfig.xml in the same folder as vray.exe."
Is this only relevant for plugins and not all the render settings?
Thanks!
Thanks!
