RPC Proxies
  • RPC Proxies
    Just downloaded the new update, loving it so far, but I noticed this RPC Proxy. Is there a .vrmesh library to download from?
    Hi Kraig,
    There is no .vrmesh library (yet). Proxies can be created in any software capable of producing .vrmesh or .abc files.
    I think you can have a look at the following thread: https://forums.chaosgroup.com/forum/...y-for-sketchup
    Ana
    Ana Lyubenova
    Product Manager
    www.chaos.com
      I'll wait for a .vrmesh library or download site to pop up, all I use is Revit. Thank you!
        Is it possible to create a .vrmesh without vray in the program you're trying to create the mesh in?
          Hey,
          Sry for coming in this thread, but I think proxy was use to populate tree and else in Revit.
          But it's only use to replace simple RPC model by a complex model ? is it true ?
          Mick
            Hi Mick,
            Revit doesn't let us import proxies directly into Revit. That's why we need the RPCs. They are stand-ins for proxies and allow for adding detail and realism to the renders.
            Kraig_Cline , use the ply2vrmesh tool that comes with the V-Ray for Revit installation to convert 3d objects to V-Ray proxies and use them in V-Ray for Revit later on. (The tool is available in V-Ray 3.60.02 version which can be downloaded from our website)
            Best,
            Ana Lyubenova
            Product Manager
            www.chaos.com
              So what you're saying Ana, is I can insert a FBX into the model then use that tool to convert it into the mesh?
                Nevermind, went to the help section and found it.
                  How do I get the program to run? I double click, right click run as admin and nothing happens. A window looks like it tries to open but still nothing.
                    It's a command line tool. Here is what you need to do.
                    Run cmd from the following location: C:\Program Files\Chaos Group\V-Ray\V-Ray for Revit\tools
                    Then type in: ply2vrmesh
                    Drag & drop the .obj file over (this will automatically add the path to it)
                    Then type in the output name.vrmesh
                    And click enter. And you will find the .vrmesh in the tools folder.
                    Let me know if I should send you a screenshot. But once you run it by yourself, you will know how to use it.
                    A.
                    Ana Lyubenova
                    Product Manager
                    www.chaos.com
                      Yes a screenshot would be helpful. I'm lost. The command prompt is fighting me, I don't know if i'm suppose to be in the command prompt or if the ply2mesh is suppose to open a new command prompt window. Clueless.
                        Ok I'm where I need to be I believe. now the issue is my Syntax I guess. dragging and dropping files isn't populating the location/file name so I'm having to type it in.. incorrectly obviously. So if I could just see a proper conversion and the syntax I should be able to get this to go through. Thank you again.
                          Sorry to be bum rushing you with these questions and self assists. I did get the .vrmesh conversion to work. Now how do I get the materials that came with the .obj to apply to the .vrmesh? It's probably in the options but I couldn't find anything to apply it, and the material options were a tad confusing.
                            You can't take them from the .obj. The ply2vrmesh tool will convert the .obj to .vrmesh taking the material IDs of the obj. Basically the IDs indicate the geometries of the model that are meant to be made of the same material. In V-Ray for Revit you will see them appearing in different colors and you can replace the colors with V-Ray material. However, you will need to create the V-Ray materials by yourself or use the library...
                            Let me know if you have any other questions.
                            Ana Lyubenova
                            Product Manager
                            www.chaos.com
                            • #15
                              Awesome. It's a little more work but the outcome is much better. Thank you!
