Displacement issues - 2D as geometry modifier fails and water level only good at 2D (material)
  • Displacement issues - 2D as geometry modifier fails and water level only good at 2D (material)
    there are two issues:
    * if the geometry modifier is used than 2D displacement doesn't work, but it works used at a material
    * the water level only looks good if 2D displacement is used at a material. Normal displacement shows a pixelated water level always.
    Micha
    This is now logged in our internal bug-tracking system under ID-number: VRW-3001
    We'll let you know when there are any updates on the matter.
    Nikoleta Garkova | chaos.com
