How to map correctly a photo on my 3D model?
  • How to map correctly a photo on my 3D model?
    Hi!
    I don't know how to do to map correctly this photo using Vray, on my 3D model.
    I would like the photo at the good scale on the model. I am loosing my hair, trying to unwrap, to map using crop inside vray panel, to try with rhino to mach the surface with a box..... I understand really nothing on how to map a photo on a rhino model, in order i can resize to have the good scale, using Vray.
    Could you please tell me, step by step, how to do?
    I had courses, i saw the Rhino Tutorial for this, and i really can't understand. From the easiest thing, that, for example, is to put the good scale for a concrete texture in the library of materials in vray, to this photo on a this 3Dmodel, it seems so difficult to do this, thanks so much to help me!
    WeTransfer is the simplest way to send your files around the world. Share large files up to 2GB for free.
    Hi marbella,
    I guess the easiest way to achieve this is using Rhino Decals:
    1. Apply any material to the object
    2. Select the object
    3. Navigate to the Decal parameters in Rhino
    4. Add a new planar decal
    5. Position the projection the way you like (you have to show the decal gizmo first - by clicking on the small green icon on the right of the decal list item)
    Please let me know if you are after something different.
    Konstantin
      Hi Constantin
      I only see now your answer, thanks
      I will try it....
      Thanks so much!
