Version 5 Update 1.1. Proxy scale
  • #16
    Moreover I have spend some time in the bug documentation process to allow you to create a better product. This sucks.
    • #17
      Hi toniboni
      We are able to reproduce it with the specific 3dm file you sent us (I'm not saying otherwise), however, we cannot get the same behavior if we try to make a proxy template file from scratch.
      We can, of course, schedule a remote session and investigate a bit further the creation process of those files and troubleshoot on the spot - if that is alright with you, you can get in touch via our contact form to do so.
      Nikoleta Garkova | chaos.com
      • #18
        Ok, we can do this, but for me it is not so much about the creation process anymore, since I'm using the newest update of Vray 5 now and I suppose that the bug will not appear here. But remote session sounds ok...I'll use the contact form.
        • #19
          Hi toniboni,
          We have identified the cause for this issue and it'll be resolved in the next update.
          The issue is logged in our internal bug tracking system as VRW-3189.
          Thank you for reporting this and excuse us for the inconvenience.
          Regrads,
          Konstantin
          • #20
            Hey that's good news! Thanks for letting me know... Excuse accepted Now I hope for the update to appear asap.
            Best regards
            Toni
            • #21
              I'm having the same problem. proxies are rendering correctly but in Rhino viewport some of them are wrongly positioned, scaled and also distorted.
              When the fix will be available? This is quite urgent.
              Thanks
              • #22
                This is exactly the same issue.
                We'll do our best to put out a hotfix that resolves it as soon as possible.
                • #23
                  Thank you.
                  • #24
                    ALTO and​​​​​​ toniboni hey guys,
                    This issue should be fixed with the latest update which you can get from here. Please test it out and let us know if you encounter any issues. Much appreciated!
                    • #25
                      Hi guys,
                      This issue is fixed in V-Ray 5 for Rhino, update 1.3
                      Excuse us for the inconvenience and let us know if you find any related issues.
                      Konstantin
                      • #26
                        I'm sorry but with this update i can't see nothing in Rhino viewport (everything is render correctly but all objects are like hidden in rhino, not only proxies...)
                        Rhino 7.6 with Vray 5 Update 1.3:
                        Click image for larger version  Name:	Screenshot Vray5.png Views:	0 Size:	158.7 KB ID:	1114426
                        Rhino 7.6 with Vray disabled:
                        Click image for larger version  Name:	Screenshot Vray Unloaded.png Views:	0 Size:	715.6 KB ID:	1114425
                        Scene files already sent to support, ticket .341-813-5371
                        • #27
                          Hi ALTO,
                          I was not able to reproduce the described behavior.
                          Can you share a simple example scene that does this for you?
                          Also, does it happen with new scenes?
                          Konstantin
                          • #28
                            Originally posted by konstantin_chaos View Post
                            Hi ALTO,
                            Konstantin
                            Hi Kostantin, as i said the scene you see in the screenshots was already sent to chaos support, ticket 341-813-5371
                            It looks ok in new scenes.
                            Thanks
                            • #29
                              OK, that's great.
                              I'll get back to you as soon as possible.
                              • #30
                                Konstantin,
                                Could you please check also this vrscene AM_Cars_03_03 in the same file? It looks wrong in Vision:
