Latest Rhino 7.11.21293.9001 + Vray for Rhino 5.2 + Vantage 1.5.2 (Build: 1200713)
Watching the video (link below) It looks like after clicking the "Starts a Vantage Live Session" button in Rhino the Command line briefly shows "Command options (IP=127.0.0.1c Port=20701): _-Render" then blank and the viewport in Rhino is linked to Vantage.
When I click the "Starts a Vantage Live Session" button I get the following:
Command: _vrayVantage
Command options ( IP=127.0.0.1 Port=20701 ): _Enter
Starting Chaos Vantage...Done
Command options ( IP=127.0.0.1 Port=20701 ): _-Render
Then "Command options ( IP=127.0.0.1 Port=20701 )" remains in the command line no matter what I press - I can't select anything in Rhino or run any commands - I can only navigate the viewport (which is not linked to the current Vantage session).
The only way to unlock Rhino is to close Vantage or (if I had them open) click the "Abort rendering" button in the Vray Options or Frame Buffer.
It doesn't seem to be file specific as far as I can tell.
I've tested it in Rhino 6.35.21222.17001 and it works as expected.
