Unknown command _vrayInstancer
  • Unknown command _vrayInstancer
    is something wrong with my installed update or is it a bug? (I called the command from the V-Ray menu.)
    Is the toolbar the latest version?
    -Micha
Name:	Screen Shot 11-08-21 at 09.51 AM.JPG
    Hi Micha,
    I don't understand what the problem is here?
    There is no vrayInstancer command available.
    The Scatter command (if that's what you're after) is vrayScatter.
    As far as the toolbar is concerned - there are some items missing.
    Here's what you should see:
    You can try restoring the Rhino toolbars.
    Note that Rhino is sometimes doing that - it stores a cache for the toolbars and does not show the correct one when a new plugin version is installed.
    Hope that helps,
    Konstantin
      I understand. I used a command which was looking like something with scatter. Seems to be an orphaned command.
      I afraid using the restore button will destroy my changes on the Rhino toolbars. I will look for an other way, there was a post in the past.
      Thank you,
      Micha
Name:	Screen Shot 11-08-21 at 11.22 AM.JPG
        I found the old post with the save toolbar refresh and it works now.
        https://forums.chaos.com/forum/v-ray...l-new-features
          Yes, exactly.
          That's what I was just about to share.
