v5.2 - GH "Material from File" causing "Render in Project" Error
  • v5.2 - GH "Material from File" causing "Render in Project" Error
    After upgrading to version 5.2 I've noticed that the emissive light materials that I have setup as "Material(s) from File(s)" in all of my render files are now causing the "Render in Project" component to throw up an error.
    Please see test file and screenshots linked/attached below.
    I've downgraded to v5.1.6 and it's working as expected.
      Hello, Paul,
      Simply delete the "V-Ray Mtl" underlying layer below the Emissive one in each of those materials, resave them as .vrmat files and everything will work.
      The bug you showcased is now logged and awaits review by our developers. Thank you for this report!
      Kind regards,
      Peter
      Peter Chaushev
      Let's keep in touch
        Ha - thanks Peter.Chaushev - 'Simply' is a relative word when you've got 100 individual material files linked up to a slider in grasshopper so you can scroll through intensity like an actual light component...
          Indeed. I underestimated the scale of the issue. Apologies.
          Can only assure you it is currently investigated by our devs and a solution will be devised and published in a minor update (v5.20.03).
          Peter Chaushev
          Let's keep in touch
            No worries Peter.Chaushev I might have overstated the number of individual materials I have just a little
            Your suggestion simplifies the material (not sure why I hadn't thought of that already) - so when I find some time I'll update them all anyway.
              Originally posted by Peter.Chaushev View Post
              Hello, Paul,
              Kind regards,
              Peter
              Hi Peter.Chaushev I've upgraded to v5.20.02 and tried your solution and it's not working.
                v5.20.01 not working either back to 5.10.06 I go.
                  Hi paul-twoatsix,
                  This issue has been fixed and the fix will make it's way in the next update (coming soon).
                  Regards,
                  Konstantin
                    Wonderful - thanks guys! All working correctly now.
                      Great to hear,
                      Thanks for the confirmation.
