GPU Optix error code 7050
  • #16
    Hi guys,
    There has been another update published recently - V-Ray 5 for Rhino, update 2.4
    Just keep in mind that if the error was popping up because of insufficient memory, chances are the new update will not fix it.
    The thing is, with the introduction of the GPU light cache (in the initial 5.2) the memory requirements of V-Ray GPU have increased a bit.
    This means that if you were rendering a scene at the limit before (using something like 7.6 GB with a 8GB GPU), it is possible that after the 5.2 release you are no longer able to render.
    Regards,
    Konstantin
