Big problem: parts of a complex scene are not rendered
  • Big problem: parts of a complex scene are not rendered
    I have complex scene and I hide unseen objects to keep the memory usage low in the past. But now my client want to get panorama views and I need to show all objects at the same time. I did a first test and enabled all objects. But now objects of the scene are invisible at the rendering, it looks like random objects are not loaded. What can I do?
    -Micha
    I have seen now that it is a GPU rendering problem and I will ask at the GPU section.
      Workaround: in RTX mode it works. I sent a bug report -> ##16268.
        OK, that's good.
        I hope that you've attached the project too.
          Yes, the project is sent per link. Good luck.
            The discussion at V-Ray GPU section is located here.
            To share here too - the issue is logged with VRW-3519 number.
            Thank you once more for reporting!
            Tsvetomira Girginova | chaos.com
            3D Support | contact us
