Qt platform error
  • Qt platform error
    recently i’m having this issue when i try to import, insert or open an obj or fbx. It happens since the last Vray update.
Name:	202202 6_1952.jpg
    I've talked with McNeel and we've notice it's something related to Vray, if i disable Vray plugin there's no problem importing obj or fbx.
    I've also tried uninstalling Vray and making a clean install but it always appears
    Any idea?
    Thanks
    If there is a crash after the message appears, there should be also a dump file(with the extension .dmp) generated in the desktop.
    Can you please send the .dmp file here: https://support.chaos.com/hc/en-us/requests/new so our devs can investigate?
    The file should be quite huge so don't worry if it ends up being over a gig. The uploading platform in the link above should be more than capable to transfer it.
    If the program is not crashing you can still force a .dmp file to be generated through the Task Manager. Right-click on the process and select Generate dump file.
      Originally posted by slavcho.brusev View Post
      Done!
      Thanks!!
        Thank you for the provided file!
        Please update Chitubox to version 1.9.1.
        Chitubox is using a global handler with the same version of Qt as V-Ray is using and that is why this is occurring.
        The issue described here is the same https://forums.chaos.com/forum/v-ray...rash-on-export
        Let me know if the update resolves the issue.
          You saved me!
          i've uninstalled and cleaned Chitubox (because i'm on a dealine) and everything works perfectly again!! i'l try version 1.9.1 a.s.a.p. but at least i know the problem source
          thanks again!
