Batch Export from VFB?
  • Batch Export from VFB?
    I can set up batch renders in rhino, and batch image processing in the VFB, but I cannot seem to batch export processed images from the VFB to their final formats. Is this by design?
    Adding a file format to the "Output Filenames Suffix" dialog, doesn't change the format. Is there a way around this?
    Dear charlie_peckar, hello.
    This V-Ray Frame Buffer feature allows now processing of multiple .vrimg files with the same layer tree changes at the same time.
    It is mostly used for animations, where layer preset should be applied on many frames, but not only.
    Output filenames suffix – Specifies a suffix added to the output image filenames.
    So, this setting isn't able to change the final file format.
    For now .vrimg is loaded as input and received as output (with the desired corrections applied).
    Similar discussion could be found here about V-Ray for Cinema 4D, where Aleksandar mentionedV-Ray Image to EXR Converter (here link for V-Ray for Rhino is applied).
    TS
    Tsvetomira Girginova | chaos.com
    3D Support | contact us
