I want to have the ring not reflect the color of the floor, so I created a wrapper of the silver material and enabled ignore objects in secondary thinking it would ignore the floor object and its reflections. However switching the ignore setting on and off does nothing to the color of the ring. What am I doing wrong? The layer/materials are set properly
Noob Issue: Ignore Objects in Secondary not working?
Hello meir_bezner.
You are on a right way to achieve your aim. You can try the following options:- To be sure you applied the right material to the right object you can first select an object and then right click on your Wrapper material in the Asset Editor and click on the "Apply to Selection" option.
- If you still prefer to apply your material to all objects in a layer using the option "Apply To Layer", then first make sure you did not apply any materials on individually selected objects. Then apply the material to the exact layer you want.
I hope this will help. If you have questions do not hesitate to ask them.
Regards,
IvelinaIvelina Mincheva
V-Ray for SketchUp | V-Ray for Rhino | QA
www.chaos.com
- Likes 1
Sorry, didn't see anyone had responded. I tried, I have the material applied via "Apply to Selection" and the layer. I still can't figure it out. I've settled with taking 2 frames, one with the background and one without, and photoshopping the reflectionless one overtop in the meantime, but any help would be appriciated! Thanks!
Hello meir_bezner!
Here is another way to achieve a result with no reflections from the surface (floor) to the object (your ring). As the surface is the one that you do not want to be reflected anywhere, its secondary rays could be overwritten.- Create a new Generic material and set its Opacity to 0. This material is now invisible, so rename it with "Invisible_mtl".
- Select your material applied to the floor.
- Add an Override attribute from "Add Attribute" option.
- For Reflection and GI select the Invisible_mlt.
Kind regards,
Ivelina
Ivelina Mincheva
www.chaos.com
