Hi, Since last update I have had alot of issue working with Rhino and V-ray. Every time i try to do some interactive rendering this messeges pop up, I dont know why the app its getting so unastable, and just to be clear this could happen even with small projects. I have identify many bugs that to me looks to be the problem, but at the end it doesnt work
1. Decals in rhino are identify as a Bad Object.
2. From last update some of the Cosmos Library objects are identify as bad object to in rhino, mostly when you merge them to change some color or texture.
3. When working with large scatter and fur scene it also happen to get a messeges on the log where it says "Warning : Max sample level set to 0 - rendering could take longer than expected. Consider setting a value to decrease the render time"
this is causing me to get render time to go beyong expected and sometimes the same render can take a 5 minutes or 1 hour, and it happen with both of my sepups
Its there any solution, since this software its no getting better with all the updates its getting worst, I remember back in time I was able to make more with less spec on my system, but the feeling rigth now its that the more computational power you have, the unstable it become.
SETUP 1
AMD Ryzen 9 7900X 12-Core Processor 4.70 GHz
RAM 64,0 DDR5 6000MHZ
NVIDIA Geforce RTX 4070 Ti 12GB
1TB Corsair MP600 PRO
SETUP 2
AMD Ryzen 9 5980HS 3.30 GHz
RAM 16,0 DDR4 4266 MHZ
NVIDIA Geforce RTX 3080 16GB
1TB WDC PC SN530
Please I need some help, this is becoming a Pain for my work flow,
SETUP 1
SETUP 2
1TB WDC PC SN530
