Viewport texture issues - Vray 6.2.0
  • Viewport texture issues - Vray 6.2.0
    After recent update of Vray, I have some issues with displaying textures on meshes.
    I did not make any change to scene. Just update Vray.
    Rendering is ok.
    Edit: Looks like it get some errors when diffuse texture is Wrapped In - Color Corrections, Spline Curve etc. Pure bitmap without corrections is displayed well.
    Hello pavol_pastork,
    I am not able to reproduce the issue so far. Could you please share with us a scene with an example mesh (with its material) exhibiting the issue. You can do this by packing your project from the Rhino menu > V-Ray > Pack Project and share the archive here, in a private message or through https://support.chaos.com/hc/en-us/requests/new​ mentioning the link to the Forum thread in the message.
    Thank you in advance!
    Kind regards,
    Iva​
    Iva Mancheva
    V-Ray for SketchUp | V-Ray for Rhino | QA
    www.chaos.com
      Hello iva_mancheva
      I had same issues with 2 more projects. It appears on mesh and open surfaces. For your information, all objects had wrapped diffuse texture (as I mentioned earlier) and had applied rhino uvw texture mapping (box, surface...).
      I will send you scene next monday, if we will not solve it til then. Thank you
        I managed to reproduce the issue and it is logged in our bug tracking system. We will let you know if there is any progress on this matter.
        Thank you for your report!
        Kind regards,
        Iva
        Iva Mancheva
        www.chaos.com
          Hello iva_mancheva,
          thank you for informations. I will be waitin for solution.
            The issue is resolved. It is now included in the upcoming v6.20.01 hotfix.
            Peter Chaushev
            Let's keep in touch
              Peter.Chaushev Thank you...
                A hotfix which fixes the issues discussed here was just released:
                https://forums.chaos.com/forum/v-ray...-now-available
                  Thank you. Looks like that isssues are solved. Good work.
