Curve piping doesn't render
  • Curve piping doesn't render
    Hey guys - the new V-ray 6.20 on current version of Rhino 7/8 doesn't render curves with curve piping modifier.
    Can you reproduce? It worked fine before the current version.
    Cheers
    Jonas
    Hello Jonish,
    Thank you for the post.
    We are aware of the issue and working on it.
    Will let you know once there is any update on the matter.
    Natalia Gruzdova | chaos.com
      Thank you, Natalia!
        Hello Jonish,
        I would like to let you know that the issue is fixed and will be available in the next hotfix.
        Kind regards,
        Iva
        Iva Mancheva
        V-Ray for SketchUp | V-Ray for Rhino | QA
        www.chaos.com
          Hi, I'm having this issue since upgrading to Rhino 8. I use curve-piping a lot. Regular _Pipe command doesn't work reliably.
            Hello joseph_charleston,
            What is the V-Ray version you are using? The issue with Curve piping is fixed with V-Ray 6.20.01 and there are no issues with the latest V-Ray updates.
            Kind regards,
            Iva
            Iva Mancheva
            www.chaos.com
              I believe everything is up to date. In the below screenshot, it can be seen that the sun on the left, which has curve piping applied to it, is not visible in the frame buffer, but the sun on the right, which was made using the same curve but with _pipe applied to it at the same radius is visible. Both objects have the same emissive yellow V-Ray material applied to them, and theoretically should have the same appearance in the frame buffer window.
              v​
                Hello, joseph_charleston,
                I am not able to reproduce the issue with V-Ray 6.20.04 with Rhino 8 and Rhino 7. Could you please share your scene, it might help us identify the issue? You can do this by packing your project from the Rhino menu > V-Ray > Pack Project and share the archive here, in a private message or through https://support.chaos.com/hc/en-us/requests/new​ mentioning the link to the Forum thread in the message.
                Thank you in advance!
                Kind regards,
                Iva
                Iva Mancheva
                www.chaos.com
                  Here is my example file
                    Thank you for the scene. I was still able to render it:
                    Could you please export a .vrscene file from this scene (Asset Editor > Render dropdown > Export V-Ray Scene File or V-Ray menu > Rendering > Export VRScene) from your machine and share it?
                    Kind regards,
                    Iva
                    Iva Mancheva
                    www.chaos.com
                      Wonderful, that gives me hope! Here is my .vrscene file
                        The reason for the Curve piping not working on your side is that you have somehow installed V-Ray for Rhino 7 on Rhino 8, in some cases like this one the V-Ray for Rhino 7 code does not work for Rhino 8. I suggest you to perform a clean reinstall by uninstalling V-Ray and making sure there are no leftover files (see https://docs.chaos.com/display/VRHINO/Uninstall+V-Ray) and then install it again by running the V-Ray installer.
                        Let me know if this fixes the issue.
                        Kind regards,
                        Iva
                        Iva Mancheva
                        www.chaos.com
                          Thank you Iva, that solved my issue.
