a small list
  • a small list
    How are these bug reports handled? I mean, for now we can read all other posts and then post only new bugs, but with some more posts it will be impossible to read everything to make sure they're not listed twice.
    I assume there is a list somewhere and you guys only add new bugs/wishes to that list
    - the options window is not resizable
    - a mirrored rectangle light will cast light into the wrong direction (the direction is not mirrored)
    - glossy reflection without fresnell option is incorrect (it seems there is a value of 2.0 by default if you uncheck fresnell).---->updated this bug in a new post here: http://www.asgvis.com/phpBB2/viewtopic.php?t=44
    a small list
    Flipside,
    Yes we are making a list much like the readme file you see at install. We are scratching them off the list as we fix them. In the nex build you all will see a list of known and resolved issues along with wishlist items.
    Thanks again for your hard work.
    Corey
    Corey Rubadue
    Director
    Chaos Group
      Re: a small list
      If this scene was saved with an older build I suggest you put the values where they belong, then save again, and see if the problem persists. Thanks,
      Joe Bacigalupa
      Developer
      Chaos Group
        a small list
        Had a problem with Glossy reflections and a relfection color that was not black (gold color, to simulate gold reflections) and the material went a pale greenish.
        Anyone else had that problem?
        /BlueShift
          a small list
          It happens in a new file too. Just start rhino, assign a reflective material to an object and turn on glossy (don't check fresnell). Give it a light grey refl color and you will see the object is not very reflective (it should show up almost mirror like but then glossy). If you use a white reflection color, reflection totally dissappears.
