I think this is more of a Rhino issue, when using the render widow command it works fine if you stay in the viewport resolution. But if you render something larger than veiwport resolution using renderwindow it doesn't see what's in the viewport. The included image was rendered larger (using Render command) that the viewport, then I changed the cube to blue and used renderwindow and drew a marquee which included the whole cube in the viewport but as you can see it only did a portion of it.
Thanks,
Glen
Thanks,
Glen
