FIXED: RCM
  • FIXED: RCM
    Trying to install b7, I get an "error Loading - Loading - \Rcm.rhp"
    The Rcm.rhp file is indeed in the Rcm directory, but it will not load (not even manually)
    (Brazil was uninstalled previously)
    Any hints ?
    Thanks
    FIXED: RCM
    Hi Thomas, good to see you
    In case you didn't read in the announcement section, the build 7 release notes ...Joeb mentions that unintalling the Brazil Wip will break VrayRhino.
    ...so, I'm thinking there's your issue. ...and perhaps you've already fixed it.
      FIXED: RCM
      hmm, I thought I read that part a couple of times :P
      Because the Brazil WIP uses RCM as well, installing VRay for Rhino will **BREAK** the current WIP of Brazil. Also if you install a Brazil WIP it will **BREAK** Vray for Rhino.
      So, I uninstalled Brazil before installing Vray; so as to start from a clean slate ... No ?
        FIXED: RCM
        Did you uninstall build 6 before installing 7? I uninstalled brazil, uninstalled build 6, installed 7 and it seems to work.
          FIXED: RCM
          ...so, you don't currently have a Brazil Wip installed, ...is that correct?
          I guess my question would be: Can one just leave Brazil installed and install Build 7 and 'break' the Brazil wip and there will be no problems?
            FIXED: RCM
            hmm, I uninstalled both Vray and Brazil, reinstalled Vray ....still no go...
              FIXED: RCM
              there has been an issue discovered on Windows 2000 machines in which a dll is missing that Rcm needs. Do you have Windows2000? If so get in contact with crubadue@asgvis.com and he can probably help you directly.
              We just discovered this issue late last night
              Joe Bacigalupa
              Developer
              Chaos Group
                FIXED: RCM
                We have a fix for this. Please e-mail us at vrfrhino@asgvis.com and we'll send you the fix.
                Corey
                Corey Rubadue
                Director
                Chaos Group
                  FIXED: RCM
                  Yes, the dll was the problem.
                  Yes, I am on win2k
                  Problem solved ... Thank You Corey.
                  -Thomas
