Re: ****Please Post All V-Ray for Rhino 4.0 v1.0 SR1 Beta bugs here.****
Hello ASGvis team
in the last 5 hours i had 3 crashes (rhino / vray crashed to the desktop without bug report window or alike). I think it happened each time, while i was manipulating the vfb in some way, last time it was after maximizing...
hello again,
i have a file where i can trigger a crash almost every time. All i have to do is hit render, manipulate the controls for the vfb and occasionally maximize the vfb. Especially color curve correction seems to be very sensitive here...
It also crashes after finishing the rendering, normally all it takes is to apply a correction curve and maximize the vfb -> crash!
i will upload the file, it would be interesting, if you could repeat this behavior
I think this one is pretty serious because it jeopardizes every modification of the vfb after you have rendered since you cannot be sure if it will crash or not. For now it might be a good idea not to maximize the vfb, since this seems to be the trigger...
@Corey: thank you Corey, I found the readme file. I installed the public beta without to deinstall the previous test beta and the installer tell me to update from the previous build to the new. Anything works fine, only the readme wasn't shown by the update.
Doe's Joe know a way per WINDOWS settings to shutdown the slaves without to confirm the spawner error message? Something like "close all programms in any case at shutdown"?
@Andy: I suppose so, you got the crash problem, because no active license is at your slaves. It should work without a license at the slaves, but ... .
The other crashes - hmm, never seen here.
Originally posted by vcube
.... i have a file where i can trigger a crash almost every time.
Good news, it crash here too.
But, I test it at my other open scenes - render it a large res and fullsize the VFB and zoom in and adjust anything - no crash. Maybe you find a way to work around for now.
Hi Micha, thank you for testing it, the file is originally quite big
--EDIT1: and was originally created in the old vray version Edit1--
, what i posted is a stripped-down version of the scene, containing only three elements but still crashing, so whatever it is it still has to be somewhere in the scene.
I have tried to reproduce the behavior on another file, up to now without any success.
--EDIT2: I seems that the problem is related to scenes originally done with the old vray version. I copy + pasted everything from the crashing scene to a new fresh rhino instance and now it is stable! EDIT2--
First new bug: if I open an old project file, the objects are set to "layer" instead to "plugin" material. At other project files material and object are complete disconected. This is a worst case for complex scenes, because all material must be reassigned.
Hello Newsgroup,
not exactly a bug maybe but still a little annoying:
when I open files created with the old vray version and hit render, the result is often quite strange (over bright reflections, over bright illumination). This seems to be connected with the multiplier values of the reflection environment map and the values for emissive Materials. After manually lowering those (e.g. from 1400 to 6 for the reflectin environment), it seems to render OK...
@asgvis: is there maybe a certain factor to correct both multipliers to archive the same look with the new version ?
P.S. : any news on the DR issue? Since if that is not working, I will probably have to switch back to the old version...
That's cause by an internal correction of the Vray engine. Now, physical cam and standard cam dosn't render so extrem different bright images.
Hello-
Just a quick update. We are looking into the issues posted above. There also some issues with mapping and licensing that we are trying to resolve. I will report back to you all as quickly as possible.
We are 99.9% sure that we have found out what is going on with DR. We will try to get a fixed build out as soon as possible. Please contact me via email if you require DR immediatly.
