Please use this thread for RDK(formerly known as RCM)-specific bugs
RDK Bugs
RCM Bugs
... hide or enable object layer hide the object, but not the mapping widget, if it is set at visible befor.www.simulacrum.de - visualization for designer and architects
Re: RCM Bugs
As mentioned in other threads, the box mapping gives crap results, the 'edges' of the box show as wide lines with a distorted texture. I really hope this gets attention, because it is a very important mapping type.You can contact StudioGijs for 3D visualization and 3D modeling related services and on-site training.
Re: RCM Bugs
... cylindrical mapping too (most if I rotate the widget). I sended you an email with subject "Geometric artefacts bug" at march 9.www.simulacrum.de - visualization for designer and architects
Re: RCM Bugs
Originally posted by Micha... cylindrical mapping too (most if I rotate the widget). I sended you an email with subject "Geometric artefacts bug" at march 9.Originally posted by GjisI just checked, and it is both for capped cylindrical and cubic mapping that the image gets distorted.
Joe Bacigalupa
Developer
Chaos Group
Re: RCM Bugs
Other issues to pass along to Andy
-Being able to press Tab to move from field to field (I can't tell you how much this gets on my nerves
-Being able to access the Safe Frame parameters via the command line with the windows suppressed (The safeframe option is there when I go to document properties, but I can't get into any of its controls. My real desire is to have a shortcut that will toggle on and off the safeframes.)Damien Alomar<br />Generally Cool Dude
Re: RCM Bugs
Did you use the Rhio sun command? Or did you use the modify button at the sun directional light options?www.simulacrum.de - visualization for designer and architects
Re: RCM Bugs
Andy, the McNeel mapping-man, requested some simple scenes demonstrating your mapping issues. Would you guys mind sending them to my email? I'll forward them along for you. Thanks guysBest regards,
Joe Bacigalupa
Developer
Chaos Group
Re: RCM Bugs
Originally posted by RValliereswhile we are at it:
when setting the sun manually each time you want to modify,the settings are reset,it should keep the settings.
Or maybe I'm misunderstanding what the issue was?Best regards,
Joe Bacigalupa
Developer
Chaos Group
