color stripes on the render image
  • #16
    Re: color stripes on the render image
    You could share your Rhino file (without the model details), so that we could test it at other computers. If there is a bug, I would like to find it.
    • #17
      Thank you very much Micha! I have already sent file on the first page this thread...
      Originally posted by Chita
      and here is a scene: scene file
      • #18
        Hmm, I tested it and got a light banding only. But if I click with the RMB in the image and look at the pixel info, than the color jump at a band is only one greystep. So, if I can see one greystep, than for me it's a question of the monitor.
        I'm not sure it's important against banding, but I would change the values:
        * enable color correction for input
        * never use a so low burn value
        * 60 IM interpolation samples are a lot, I use 20..30 most
        * LC sample size 0.02 is quite high, I use 0.01 .. 0.005 most
        * LC "use for glossy rays" could be enabled
        • #19
          Thnx Micha for a tests and advice! I must try it..
          And i has befor one question..
          ......Is able, then qualitty of a render influence harware ? I try a render on "home-PC" (before in work) and i think the result ist better like from work-PC....
          It is possible..?
          • #20
            It is possible..?
            I think no. If the setup is the same, than both output images should be the same. If I would test it, than I would compare the output images at the same screen.
            • #21
              I was it tested, therefore i have this quaestion....I note, then i use like primari engine DMC, then the banding is out too....maybe is problem in irradiance map....://
              • #22
                Hmm, and there is no noise that hide the banding? Maybe one of the ASGvis moderators could test it.
                • #23
                  I set high qualitty of a render to minimize a noise that not occured distortion....
                  One more thanks Micha for your time in this problem!
                  • #24
                    Here is next one image.....
                    This image show then the reflection is not affect a banding...:/
                    And unfortunately, HDR format (16 or 32 bit...) is not solution too (
                    • #25
                      I found one solution of this problem....When i use rectangural light and the choice "store with irradiance map" is off, then the stripes is out.....
                      But rectagural light make problems in interior - sometime nonsense bleaching in negative corners, like here: http://forum.asgvis.com/index.php?topic=7331.0
