Talk about lens effect
  • Talk about lens effect
    today I tested the lens effect of the final and I ask me, doe's the Glare effect work? In "from image" mode I don't get any effect, also at weight 100 and any size. Only if I switch to one of the both other modes it works.
    Some suggestions:
    * The complete lens effect setup should be able to be saved and loaded (important for rerender an image with the same look)
    * Couldn't the lens parameters not saved to the Rhino file too?
    * Since per default no glare image is loaded, the default mode should be "glare type from camera params". At the moment per default glare doesn't work because the missing glare image.
    * it could be nice to set a numerical input of the values to at the area there the value is shown
    (like here? http://www.spot3d.com/vray/help/200R...enseffects.htm)
    * it could be great if the "on" flag would allow to disable the effect, so that the user can quick compare effect/noeffect without to move the weight slider
    * Where can be found a documentation of the mask options?
    * size - only an idea - couldn't it be useful to work with a size relative to the image size so that a big rendering looks like the smaller prerendered image?
    Great to see that the lens effects can be applied to an own render channel only. Is there a way to set an "automatic save" for specific channels if a RGB color channel is saved?
