dialogs lose focus and cannot regain control of the software
  • dialogs lose focus and cannot regain control of the software
    This has been a problem since the release of 1.50 but i've finally figured out how to reproduce the problem. sometimes dialog boxes get hidden behind other windows and lose focus. it is then impossible to cancel and regain focus. the only solution is to close rhino and reopen the file.
    here's how to reproduce the problem.
    open rhino but don't maximize, so you can still click on the desktop or other program windows. open material editor. right click on a material and select "apply material to layer". a dialog opens to browse layers. instead of selecting a layer, click on the desktop. you can even just click on the main rhino window. the dialog loses focus and disappears, and cannot be retrieved.
    this also can happen when browsing for image maps if the browser window is smaller than the material editor window. it's completely irritating. you have to close rhino and reopen, which is a real chore for larger files.
    i've also sent this as a bug report case 9414
    thanks!
    emil mertzel
    vray4rhinoWiki
    Lookinglass Architecture and Design
    If this is what I think,it happens to me also,you don't have to close rhino,minimize rhino,the dialog box is hidden under Rhino's window,so by minimizing it you get access to what is under.
    Renee
      Yes sometimes that works, but many times it doesn't and I have to quit rhino. Painful.
      emil mertzel
      vray4rhinoWiki
        I suffer a lot from this too. Always when using the materials editor. It seems that the materials editor locks up or looses the vray license (?) and I loose ability to close the windows. I can however click in the main rhino window and save the file before quitting rhino, but I do loose all the edits I've done in the materials editor.
        As Emil said, this can waste a lot of time with large models.
        Rob.
        .:www.mcphersonyachtdesign.com:.
          yeah, it's common with the material editor. if the window that loses focus is big enough, you can still find it and click on it to bring it forward. but if it's smaller than the material editor, it hides behind. dialogs need to be modal.
          emil mertzel
          vray4rhinoWiki
            win+tab helps.
            best
            Marcel
              alt+tab
              Sorry
              Marcel
                Hi Marcel - sometimes this helps. sometimes the dialog doesn't appear in the list of windows to choose from, and you have to close rhino.
                emil mertzel
                vray4rhinoWiki
                  Yep, got it reproduced here. We'll get this fixed.
                  Corey Rubadue
                  Director
                  Chaos Group
                    thank you!!!
                    emil mertzel
                    vray4rhinoWiki
                      Best news I've had all year.. thanks Corey!
                        This is fixed in the today nightly builds.
                        Corey Rubadue
                        Director
                        Chaos Group
                          amazing!
                          (now we just need an official release so it works on campus... =)
                          emil mertzel
                          vray4rhinoWiki
                            Soon enough...
                            Corey Rubadue
                            Director
                            Chaos Group
                              emil mertzel
                              vray4rhinoWiki
