URGENT ISSUE, bug (?) in spherical camera Vray 3 for Rhino
  • URGENT ISSUE, bug (?) in spherical camera Vray 3 for Rhino
    I have a deadline approching on friday and run in a serious issue with Vray 3 for Rhino. Hope someone can help.
    I need to render a number of 360 degree spherical images. Under Vray 2 for Rhino that was never an issue. All was working nice and easily.
    Now I wanted to do the same while using the full 64bit power & 24 GB RAM by using Vray 3 for Rhino.
    My Vray 2 runs only with 32Bit....
    When I do set the spherical camera (without the stereo enabled) I get a double image instead of one (see below).
    When I set stereo I get even a quadruple image in one.
    As Google VR splits the image automatically in two when I use it in the smartphone powered VR Box headset I need one image showing the whole 360 sphere as input.
    Not a double image.
    This is what I get on a test scene WITHOUT stereo enabled (=720degrees instead of 360degrees):
    This is what I get WITH stereo enabled (=1440degrees instead of 720degrees):
    Images attached.
    I'd really appreciate any help! I need to meet that deadline....
    Thanks so much,
    Pretty
    Hello,
    Please try the suggestions described in our email correspondence.
    If the issue persists, submit the scene for investigation by replying to our email (support@chaosgroup.com) and sending it either directly or through a file-sharing service of your choice.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
