When I go to V-Ray->Export->Pack Project, I get to enter a filename and a box that says "V-Ray is packing your scene..." for one second but no file is created.
Pack project doesn't work
Originally posted by mgibeault View PostWhen I go to V-Ray->Export->Pack Project, I get to enter a filename and a box that says "V-Ray is packing your scene..." for one second but no file is created.
It's related to the path of a texture for a material... the issue occurs if there is a texture with a too long path or with folders with the same name one inside the other, (example: /folder/folder/folder/texture.jpg)
Hope this will be fixed in the next release,
Hello,
I assume you are using the latest V-Ray 3.40.03 build?
Does Grigio's advice make a difference?
Could you please double-check whether your problem occurs only with a specific project? If this occurs with any project, please perform a clean reinstall and let me know if that solves it.
If it doesn't, please contact support@chaosgroup.com and request a remote viewing session so my colleagues can get to the bottom of the issue.
Kind regards,
PeterPeter Chaushev
Let's keep in touch
It is hard to tell based on insufficient info. Since you mentioned network drives, could you please try to reproduce the issue on another machine and/or with another user account?
Additionally, if you are willing to have a remote viewing session with our support team or provide a scene which produces the issue (obviously without sending the assets) we should be able to figure it out. Please send an email at support@chaosgroup.com to let us know how you would like to proceed.
Kind regards,
PeterPeter Chaushev
Let's keep in touch
