Vray NEXT Trial
  • Vray NEXT Trial
    Hi There.
    We have the latest VRay but i wanted to try the Vray NEXT that was just released as a trail to see before upgrading.
    However when the installation is complete (trial version) it says it cant obtain a vray GUI license.
    Tried uninstalling and re-installing a few times but no luck.....
    Please advise
    Cheers
    Bluesky
    have you registered for the trial first?
    J.
      Hello, Bluesky,
      Could you please visit https://www.chaosgroup.com/trial/vray-rhino and register for the trial first?
      Kind regards,
      Peter
      Peter Chaushev
      Let's keep in touch
        I followed the link in the newsletter.....signed in and then received an email with a download link.....downloaded the trail installer and installed....no section to activate trail though...still stuck with cannot obtain GUI ?
          Thank you for your reply!
          Please make sure you are logged in the Online License Server (OLS) with the same username you've used when registering. To access your license server open the Start menu and start typing in "Manage Chaos License Server" (without quotes).
          If you are already logged in with the correct account but the issue persists, please send us an email at support@chaosgroup.com and my colleagues will provide you with live assistance!
          Kind regards,
          Peter
          Peter Chaushev
          Let's keep in touch
            Hello,
            is possible to install VRay Next trial without uninstalling previous Vray 3 (have both on one machine)
            Thank you.
              Hello,
              It is not possible to use V-Ray Next for SketchUp and other previous versions simultaneously. Upon installing V-Ray Next, V-Ray 3 will be uninstalled. This applies the other way around as well - to get V-Ray 3 back, you would first need to uninstall V-Ray Next and then reinstall V-Ray 3.
              To access older installers, visit https://download.chaosgroup.com/?platform=56 and check "Show older versions".
              Keep in mind V-Ray is not forward-compatible, meaning V-Ray 3 is not guaranteed to work properly with scenes saved using V-Ray Next.
              On a side note, if you purchase a V-Ray Next license it will work with V-Ray 3, allowing you to complete unfinished projects with V-Ray 3 if needed.
              Kind regards,
              Peter
              Peter Chaushev
              Let's keep in touch
                Hi Peter,
                I'm using your workaround with registry edit for switching between V-Ray 3 and 4 and it works just fine. (Only I can't find it atm)
                Cheers
                Jonas
                  That workaround was suitable for beta testing. As noted in the disclaimers I've posted in the beta forum, we cannot recommend switching registry data for commercial users.
                  Kind regards,
                  Peter
                  Peter Chaushev
                  Let's keep in touch
                    Looking so much forward to see the webminar on vray next from today. Hope will be published soon
                    Best
                      The V-Ray Next for Rhino webinar is now available on YouTube:
                      https://www.youtube.com/watch?v=uUi2cHrcbKo
                      Peter Chaushev
                      Let's keep in touch
