My usual method for doing this is to add a wallpaper in the viewport (properties panel - wallpaper), then set the render output to the same dimensions as the image.
Next I align the object with the wallpaper, add lights so that they match the image. For this image I might use a dome light and put the background image into it to give a similar environment lighting colouration and reflections.
You could add a floor if necessary, something matching the wood.
Then I would render it and save out as an image format that saves transparency (I use png/exr).
Next in photoshop put the render over the top of the original image used as the background, and composite the two images together.
You might also like to render out a z-Depth pass to add the focal blur. This can be added as a photoshop layer, copied into an alpha channel and then using Filter->Blur->Lens Blur, with the alpha channel selected as the Depth Map.
There are more advanced ways to do this, but this should get you up and running.
