Sub object materials
  • Sub object materials
    Is there a way to assign VRAY materials to individual polysurface faces?
    Thanks
    Hi jvparc,
    Applying materials to a polysurface is not yet supported in Rhino currently so we are not able to implement it. However, as a workaround, you can prepare the desired V-Ray materials, select the surfaces by Ctrl+Shift+clicking on them, and then from the Rhino menu > Properties > Materials, select the V-Ray materials you want applied for each face. See attached gif for a better visual explanation: http://ftp.chaosgroup.com/support/sc...8_16-24-05.gif
    Hope that helps!
    Nikoleta Garkova | chaos.com
      Thanks for the reply - that's not working for me on Vray 3.6 - I'll just extract surfaces.
      Best,
      J
        nikoleta.garkova Thanks for the tip! I didn't know each face can have different material assigned!
        Jonas
          Hi jvparc,
          Support for face assignments was added in V-Ray Next.
          We did not originally have it in V-Ray 3 since it was introduced at a later stage in Rhino.
          Konstantin
