Aces
  • Aces
    Hello
    is there a way to have the same colormanagement for aces in the latest rhino ?
    Thanks!
    Really no answer from Chaos ?...
    What i hoped with the collection, is that we can somehow have the same color pipelines between all the apps (max, rhino, vantage...)
      I'm not sure if this is what you need, but in V5 new frame buffer you have the chance to add a filmic layer, then 2 options for tonemapping space: Linear sRGB or ACEScg.
Name:	Screenshot 2020-12-14 140628.png
      JoaquĆ­n Laborda - www.trumdesign.com
        Filmic tonemap (with aces) is not the same as ocio and aces setup
          OK, this color details are not my area, but while you wait for Chaos answer I try one more time...
          In display correction section, there is OCIO and option to load a settings file, am I closer?
Name:	Screenshot 2020-12-14 142435.png
            Yeah, but in max for instance, there is also an option to have the ACES color workflow that adapts the colors of vraysky etc
              Hello, muoto ,
              Thank you for your request and apologies for the delayed response!
              Implementing an ACEScg workflow is being considered, although we have not yet determined how to best suit it for the needs of V-Ray for Rhino users.
              This task's priority will be raised after the upcoming V-Ray 5, Update 1.
              Kind regards,
              Peter
              Peter Chaushev
              www.chaos.com
                Thanks, it's just a matter of being able to have the same setups and results between the collection apps !
                  I would really like to have the same features exactly as in max.
                  I Imagine to see under the configuration tab 2 lines for color management:
                  1st: (srgb/aces) primaries
                  2nd (auto rgb primaries for vraybitmap textures)
                  And inside the bitmap options the same we have in vray for max:
                  1st rgb color space (srgb/aces)
                  2nd color space transfer option (Inverse gamma/srgb)
                  Obviously this stuff should be under the advanced options and visible only to advanced users.
                    Thank you all for your input. It will be considered!
                    Kind regards,
                    Peter
                    Peter Chaushev
                    www.chaos.com
