How can I disable the shadow of object?
  • How can I disable the shadow of object?
    As per topic, thank you very much!
    Per material option: add Attribute ...
    Click image for larger version  Name:	Screen Shot 04-01-21 at 08.37 AM.JPG Views:	0 Size:	34.8 KB ID:	1109464
      Hi pun1407
      As Micha already kindly mentioned, you can use the Add Attribute buttons and select additional attributes that can add up to the appearance of the material applied on that specific object. By selecting Raytrace Properties and then disabling Cast Shadows, all objects with this material applied will not cast shadows. See further here: https://docs.chaosgroup.com/display/...raceProperties
      There is also a way to disable shadows globally, by going to V-Ray Asset Editor > Render Parameters > Switches > Shadows, as described here.
      Nikoleta Garkova | chaos.com
        Hi, nikoleta.garkova
        Thank you for your reply
        , I want to disable Cast Shadows by object, not by material, such as block, polysurface, mesh, etc..?
          Hi pun1407,
          Currently, we are not offering options to disable shadows from the object itself; it can be done either globally or per material, which when applied to a given object, will do the same.
